Zum Hauptinhalt wechseln
HKC P776A Motherboard Replacement
Was du brauchst
  1. HKC P776A Motherboard Replacement, Separating Digitizer and Case: Schritt 1, Bild 1 von 1
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Motherboard Replacement: Schritt 2, Bild 1 von 2 HKC P776A Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Motherboard Replacement, Separating the Screen and Digitizer: Schritt 3, Bild 1 von 2 HKC P776A Motherboard Replacement, Separating the Screen and Digitizer: Schritt 3, Bild 2 von 2
    • Use your fingers to pop the screen out from the digitizer.
  4. HKC P776A Motherboard Replacement, Removing the Optical Cord from the Motherbaord: Schritt 4, Bild 1 von 1
    • With the plastic opening tool, lift the black latch up.
  5. HKC P776A Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Pull the optical cord out from the motherboard.
  6. HKC P776A Motherboard Replacement, Separating the Screen and the Digitizer: Schritt 6, Bild 1 von 2 HKC P776A Motherboard Replacement, Separating the Screen and the Digitizer: Schritt 6, Bild 2 von 2
  7. HKC P776A Motherboard Replacement, Removing the Cable from the Motherboard: Schritt 7, Bild 1 von 2 HKC P776A Motherboard Replacement, Removing the Cable from the Motherboard: Schritt 7, Bild 2 von 2
    • Use the tip of the spudger to release the latches on the motherboard.
  8. HKC P776A Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the cable from the motherboard.
  9. HKC P776A Motherboard Replacement, Removing the Cable from the Moatherboard: Schritt 9, Bild 1 von 2 HKC P776A Motherboard Replacement, Removing the Cable from the Moatherboard: Schritt 9, Bild 2 von 2
  10. HKC P776A Motherboard Replacement: Schritt 10, Bild 1 von 2 HKC P776A Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Remove the camera from the device.
  11. HKC P776A Motherboard Replacement, Wifi Antenna: Schritt 11, Bild 1 von 2 HKC P776A Motherboard Replacement, Wifi Antenna: Schritt 11, Bild 2 von 2
    • Peel off the tape that is attaching the wifi antenna to the case.
  12. HKC P776A Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Using the soldering iron, heat up the solder that is attaching the antenna to the motheboard.
    • The heat from the soldering iron may cause personal injury or damage the internal components of the tablet.
  13. HKC P776A Motherboard Replacement: Schritt 13, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Desoldering Pump
    $3.99
    Kaufen
    • Suck up the leftover solder using the desoldering pump.
    • Remove the wifi antenna from the motherboard.
  14. HKC P776A Motherboard Replacement, Battery: Schritt 14, Bild 1 von 1
    • Insert the plastic opening tool between the battery and case.
    • Apply leverage to break the glue that is attaching the battery to the case.
  15. HKC P776A Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Continue breaking the glue along the perimeter of the battery until the battery can be removed.
    • Breaking all the glue between the battery and case may take a long time.
  16. HKC P776A Motherboard Replacement: Schritt 16, Bild 1 von 2 HKC P776A Motherboard Replacement: Schritt 16, Bild 2 von 2
    • Using the soldering iron, heat up the solder that is attaching the battery to the motheboard.
  17. HKC P776A Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Remove the battery from the motherboard.
  18. HKC P776A Motherboard Replacement, Motherboard: Schritt 18, Bild 1 von 3 HKC P776A Motherboard Replacement, Motherboard: Schritt 18, Bild 2 von 3 HKC P776A Motherboard Replacement, Motherboard: Schritt 18, Bild 3 von 3
    • Using the screwdriver, remove the four 4mm by 1.5mm screws that are attaching the motherboard to the case.
  19. HKC P776A Motherboard Replacement: Schritt 19, Bild 1 von 2 HKC P776A Motherboard Replacement: Schritt 19, Bild 2 von 2
    • Remove the black material that is covering the speaker.
  20. HKC P776A Motherboard Replacement: Schritt 20, Bild 1 von 1
    • Insert the spudger into the speaker slot on the back of the case.
  21. HKC P776A Motherboard Replacement: Schritt 21, Bild 1 von 1
    • Push the speaker out of the case with the spudger.
  22. HKC P776A Motherboard Replacement: Schritt 22, Bild 1 von 1
    • Remove the motherboard from the case.
Abschluss
Ryan Gornati
409 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 7-6, Remmell Winter 2015 Mitglied von USF Tampa, Team 7-6, Remmell Winter 2015
USFT-REMMELL-W15S7G6
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 164
