Zum Hauptinhalt wechseln
HMDX Chill Front Buttons Replacement
Was du brauchst
  1. HMDX Chill Front Buttons Replacement, Remove Rubber Base: Schritt 1, Bild 1 von 3 HMDX Chill Front Buttons Replacement, Remove Rubber Base: Schritt 1, Bild 2 von 3 HMDX Chill Front Buttons Replacement, Remove Rubber Base: Schritt 1, Bild 3 von 3
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
  2. HMDX Chill Front Buttons Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
  3. HMDX Chill Front Buttons Replacement: Schritt 3, Bild 1 von 2 HMDX Chill Front Buttons Replacement: Schritt 3, Bild 2 von 2
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
  4. HMDX Chill Front Buttons Replacement, Front Buttons: Schritt 4, Bild 1 von 1
    • Using a metal spudger, push the small latch upwards towards the button from the bottom of the base.
    • These are located underneath the rubber base, prior to removal.
  5. HMDX Chill Front Buttons Replacement: Schritt 5, Bild 1 von 2 HMDX Chill Front Buttons Replacement: Schritt 5, Bild 2 von 2
    • Insert a spudger into the slit between the bottom of the buttons and the speaker base.
    • Push the buttons upwards, away from the base, until they come loose.
    • Use your hand to pull the linked buttons off the base.
Abschluss
EWU-Giguere-S16S1G1 Mitglied von EWU-Giguere-S16S1G1
Community
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
where can I buy new front buttons for replacement?
syanco_jim - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 470
