Einleitung
If the buttons on the HMDX Chill no longer function properly, you will need to disassemble and replace the buttons. This guide will walk you through removing the buttons from the HMDX Chill without breaking them. This guide also gives you information on how to replace new buttons easily.
Was du brauchst
Insert a metal spudger under the rubber base.
Pry the rubber base off.
Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
Using a metal spudger, push the small latch upwards towards the button from the bottom of the base.
Insert a spudger into the slit between the bottom of the buttons and the speaker base.
Push the buttons upwards, away from the base, until they come loose.
Use your hand to pull the linked buttons off the base.
