Zum Hauptinhalt wechseln
HMDX Jam Plus Battery Replacement
Was du brauchst
  1. HMDX Jam Plus Battery Replacement, Battery: Schritt 1, Bild 1 von 3 HMDX Jam Plus Battery Replacement, Battery: Schritt 1, Bild 2 von 3 HMDX Jam Plus Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus Battery Replacement: Schritt 2, Bild 1 von 2 HMDX Jam Plus Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus Battery Replacement: Schritt 3, Bild 1 von 2 HMDX Jam Plus Battery Replacement: Schritt 3, Bild 2 von 2
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus Battery Replacement: Schritt 4, Bild 1 von 3 HMDX Jam Plus Battery Replacement: Schritt 4, Bild 2 von 3 HMDX Jam Plus Battery Replacement: Schritt 4, Bild 3 von 3
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus Battery Replacement: Schritt 5, Bild 1 von 3 HMDX Jam Plus Battery Replacement: Schritt 5, Bild 2 von 3 HMDX Jam Plus Battery Replacement: Schritt 5, Bild 3 von 3
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus Battery Replacement: Schritt 6, Bild 1 von 2 HMDX Jam Plus Battery Replacement: Schritt 6, Bild 2 von 2
    • Use new adhesive to secure battery back to the rest of the device.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Montana Tech, Team 10-3, Shirk Fall 2015 Mitglied von Montana Tech, Team 10-3, Shirk Fall 2015
MTUM-SHIRK-F15S10G3
4 Mitglieder
4 Anleitungen geschrieben
6 Kommentare
Where may battery be purchased?
Thanks,
zappenfusen
warnsdorff - Antwort
Where to purchase battery for hmdx jam speaker
Frank David -
Where can a battery be purchased?
robertwacker - Antwort
What kind (especifications) that battery?
vecchio.farias - Antwort
Where to buy battery for HMDX JAM.Bluetooth speaker
Frank David - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 37
Insgesamt: 7,173
