Zum Hauptinhalt wechseln
HMDX Jam Plus Speaker Replacement
Was du brauchst
  1. HMDX Jam Plus Speaker Replacement, Battery: Schritt 1, Bild 1 von 3 HMDX Jam Plus Speaker Replacement, Battery: Schritt 1, Bild 2 von 3 HMDX Jam Plus Speaker Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus Speaker Replacement: Schritt 2, Bild 1 von 2 HMDX Jam Plus Speaker Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus Speaker Replacement: Schritt 3, Bild 1 von 2 HMDX Jam Plus Speaker Replacement: Schritt 3, Bild 2 von 2
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus Speaker Replacement: Schritt 4, Bild 1 von 3 HMDX Jam Plus Speaker Replacement: Schritt 4, Bild 2 von 3 HMDX Jam Plus Speaker Replacement: Schritt 4, Bild 3 von 3
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus Speaker Replacement: Schritt 5, Bild 1 von 3 HMDX Jam Plus Speaker Replacement: Schritt 5, Bild 2 von 3 HMDX Jam Plus Speaker Replacement: Schritt 5, Bild 3 von 3
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus Speaker Replacement: Schritt 6, Bild 1 von 2 HMDX Jam Plus Speaker Replacement: Schritt 6, Bild 2 von 2
    • Use new adhesive to secure battery back to the rest of the device.
  7. HMDX Jam Plus Speaker Replacement, Speaker: Schritt 7, Bild 1 von 2 HMDX Jam Plus Speaker Replacement, Speaker: Schritt 7, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from device.
  8. HMDX Jam Plus Speaker Replacement: Schritt 8, Bild 1 von 1
    • Use the plastic opening tool to pry the glue away from the wire. Be careful not to damage the wire.
  9. HMDX Jam Plus Speaker Replacement: Schritt 9, Bild 1 von 2 HMDX Jam Plus Speaker Replacement: Schritt 9, Bild 2 von 2
    • Use the plastic opening tool to separate the center plastic piece from the rest of the device.
    • Gently lift the center plastic piece and feed the speaker wire through the hole.
  10. HMDX Jam Plus Speaker Replacement: Schritt 10, Bild 1 von 2 HMDX Jam Plus Speaker Replacement: Schritt 10, Bild 2 von 2
    • Use the plastic opening tool to separate the speaker grate from the rest of the device.
  11. HMDX Jam Plus Speaker Replacement: Schritt 11, Bild 1 von 2 HMDX Jam Plus Speaker Replacement: Schritt 11, Bild 2 von 2
    • Carefully remove the speaker through the top of the device.
    • Apply new adhesive to the edge of the replacement speaker and the edge of the speaker grate to ensure they do not wiggle loose.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Montana Tech, Team 10-3, Shirk Fall 2015 Mitglied von Montana Tech, Team 10-3, Shirk Fall 2015
MTUM-SHIRK-F15S10G3
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 1,397
