Einleitung
The microphone is soldered into the motherboard. This guide requires a knowledge of soldering. The back panel must be removed to access the microphone.
Was du brauchst
Insert the smallest plastic opening tool into the SD card port. Gently pry until the back panel separates from the screen panel.
Slide the opening tool along the seam between the back panel and the screen panel, prying the panels apart as you move around the edges.
