Einleitung
To access the internal components of the HP 14-dq0051dx, you need to remove the outer panel on the bottom of the device. You'll need to remove the back case to for most repairs.
Before beginning this guide, power down the laptop and disconnect your device from the AC adapter.
Was du brauchst
Turn the laptop upside down so the backside is facing up.
Use a Phillips #1 screwdriver to remove eight screws from the back case.
Turn the laptop over and open the screen.
Insert the opening tool into the seam between the bottom panel and the keyboard.
Run the opening tool along the entire seam to separate the bottom panel.
Once the bottom panel is separated from the laptop, carefully close the laptop and turn it upside down.
Place both your hands on opposite ends of the bottom panel, and lift up and remove the panel.
