Zum Hauptinhalt wechseln
HP 14-dq0051dx Keyboard Replacement
Was du brauchst
  1. HP 14-dq0051dx Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 2 HP 14-dq0051dx Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Turn the laptop upside down so the backside is facing up.
    • Use a Phillips #1 screwdriver to remove eight 2.5mm screws from the back case.
  2. HP 14-dq0051dx Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Turn the laptop over and open the screen.
    • Insert the opening tool into the seam between the bottom panel and the keyboard.
    • Run the opening tool along the entire seam to separate the bottom panel.
    • You may hear clicking as you release the taps that secure the case.
  3. HP 14-dq0051dx Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Once the bottom panel is separated from the laptop, carefully close the laptop and turn it upside down.
    • Place both your hands on opposite ends of the bottom panel, and lift up and remove the panel.
  4. HP 14-dq0051dx Keyboard Replacement: Schritt 4, Bild 1 von 3 HP 14-dq0051dx Keyboard Replacement: Schritt 4, Bild 2 von 3 HP 14-dq0051dx Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the five 2.5 mm screws that secure the motherboard cover.
    • Remove the motherboard cover from the laptop.
  5. HP 14-dq0051dx Keyboard Replacement: Schritt 5, Bild 1 von 3 HP 14-dq0051dx Keyboard Replacement: Schritt 5, Bild 2 von 3 HP 14-dq0051dx Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the four 2.5 mm screws that secure the battery.
    • Remove the battery from the laptop.
  6. HP 14-dq0051dx Keyboard Replacement: Schritt 6, Bild 1 von 3 HP 14-dq0051dx Keyboard Replacement: Schritt 6, Bild 2 von 3 HP 14-dq0051dx Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Use the blue opening tool to flip up the small locking flap from the ZIF connector that attaches the touchpad cable to the motherboard.
    • Gently pull the ribbon cable out from the connector.
    • Ensure that the connector is pulled out gently as this is connector is very easy to damage
  7. HP 14-dq0051dx Keyboard Replacement: Schritt 7, Bild 1 von 2 HP 14-dq0051dx Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Gently unplug the keyboard connector from the motherboard.
  8. HP 14-dq0051dx Keyboard Replacement: Schritt 8, Bild 1 von 3 HP 14-dq0051dx Keyboard Replacement: Schritt 8, Bild 2 von 3 HP 14-dq0051dx Keyboard Replacement: Schritt 8, Bild 3 von 3
    • Lift up the small compartment with your finger.
    • Pull the flat cable out of the connector.
  9. HP 14-dq0051dx Keyboard Replacement: Schritt 9, Bild 1 von 3 HP 14-dq0051dx Keyboard Replacement: Schritt 9, Bild 2 von 3 HP 14-dq0051dx Keyboard Replacement: Schritt 9, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the single 1 mm screw that secure the WiFi card.
    • Pull the WiFi card out of its slot
    • Pull the WiFi card out slowly and gently as to not damage the card or the slot
  10. HP 14-dq0051dx Keyboard Replacement: Schritt 10, Bild 1 von 2 HP 14-dq0051dx Keyboard Replacement: Schritt 10, Bild 2 von 2
    • Pull the charging port cable away from the connector in the same direction as the individual wires to unplug the charge port connector.
    • Remove the charging port.
  11. HP 14-dq0051dx Keyboard Replacement: Schritt 11, Bild 1 von 2 HP 14-dq0051dx Keyboard Replacement: Schritt 11, Bild 2 von 2
    • Lift up the port using the blue opening tool.
    • Continue to lift up until it is unplugged from the motherboard.
  12. HP 14-dq0051dx Keyboard Replacement: Schritt 12, Bild 1 von 2 HP 14-dq0051dx Keyboard Replacement: Schritt 12, Bild 2 von 2
    • Place both hands on opposite corners of the motherboard and carefully lift it up to remove it from the laptop.
    • Now the motherboard has been successfully removed and is ready to be replaced!
  13. HP 14-dq0051dx Keyboard Replacement: Schritt 13, Bild 1 von 3 HP 14-dq0051dx Keyboard Replacement: Schritt 13, Bild 2 von 3 HP 14-dq0051dx Keyboard Replacement: Schritt 13, Bild 3 von 3
    • Remove the two 2.5 mm screws that secure the motherboard cover using a Phillips #1 screwdriver.
    • Gently pull the component out of the laptop
  14. HP 14-dq0051dx Keyboard Replacement: Schritt 14, Bild 1 von 3 HP 14-dq0051dx Keyboard Replacement: Schritt 14, Bild 2 von 3 HP 14-dq0051dx Keyboard Replacement: Schritt 14, Bild 3 von 3
    • Remove the signle 2 mm screws that secure the side cover using a Phillips #0 screwdriver.
    • Pull the side cover off gently
  15. HP 14-dq0051dx Keyboard Replacement: Schritt 15, Bild 1 von 3 HP 14-dq0051dx Keyboard Replacement: Schritt 15, Bild 2 von 3 HP 14-dq0051dx Keyboard Replacement: Schritt 15, Bild 3 von 3
    • Remove the six 2.5 mm screws that secure the keyboard to its hinges using a Phillips #1 screwdriver.
    • Once unscrewed, pull the hinge tabs upward gently using your hands
  16. HP 14-dq0051dx Keyboard Replacement: Schritt 16, Bild 1 von 1
    • Place both hands on opposite corners of the keyboard and carefully lift it off the laptop
Abschluss
Akash
601 Reputation
3 Anleitungen geschrieben
IUPUI, Team 2-4, Harley Fall 2023 Mitglied von IUPUI, Team 2-4, Harley Fall 2023
IUPUI-HARLEY-F23S2G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 20
Insgesamt: 92
