Zum Hauptinhalt wechseln
HP 14-dq0051dx RAM Replacement
Was du brauchst
  1. HP 14-dq0051dx RAM Replacement, Back Case: Schritt 1, Bild 1 von 2 HP 14-dq0051dx RAM Replacement, Back Case: Schritt 1, Bild 2 von 2
    • Turn the laptop upside down so the backside is facing up.
    • Use a Phillips #1 screwdriver to remove eight screws from the back case.
  2. HP 14-dq0051dx RAM Replacement: Schritt 2, Bild 1 von 1
    • Turn the laptop over and open the screen.
    • Insert the opening tool into the seam between the bottom panel and the keyboard.
    • Run the opening tool along the entire seam to separate the bottom panel.
    • You may hear clicking as you release the taps that secure the case.
  3. HP 14-dq0051dx RAM Replacement: Schritt 3, Bild 1 von 1
    • Once the bottom panel is separated from the laptop, carefully close the laptop and turn it upside down.
    • Place both your hands on opposite ends of the bottom panel, and lift up and remove the panel.
  4. HP 14-dq0051dx RAM Replacement, Battery: Schritt 4, Bild 1 von 3 HP 14-dq0051dx RAM Replacement, Battery: Schritt 4, Bild 2 von 3 HP 14-dq0051dx RAM Replacement, Battery: Schritt 4, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the four 2.5 mm screws that secure the battery.
    • Remove the battery from the laptop.
  5. HP 14-dq0051dx RAM Replacement, RAM: Schritt 5, Bild 1 von 2 HP 14-dq0051dx RAM Replacement, RAM: Schritt 5, Bild 2 von 2
    • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
    • The RAM stick will pop up by a few millimeters.
    • Remove it at an angle and not straight up so you don't damage the socket.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 51
Insgesamt: 788
