Einleitung
This guide will walk you through removing the backside cover of an HP 14-fq1025nr laptop to access its components.
Was du brauchst
Use a pair of tweezers to grab and pull the feet off of the cover.
Remove the two 4 mm screws using a Phillips #0 screwdriver.
Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
