Einleitung
This guide will teach you how to remove a HP 14-fq1025nr keyboard and replace it with a new one. The keyboard allows for input to be typed into the computer. A faulty keyboard may result in input being incorrect and/or not being processed by the computer. For additional information and help with troubleshooting the keyboard, refer to our troubleshooting page. This replacement may require the use of a razorblade in order to remove some small parts holding down the keyboard component itself.
NOTE: The screen will need to be removed first to have full access to the keyboard cover.
WARNING: The computer uses a lithium-ion battery which contains toxic substances / flammable substances. Handle with caution.
Was du brauchst
Remove the two 4 mm screws using a Phillips #0 screwdriver.
Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
Remove the four gray 3 mm screws holding down the battery using a Phillips #0 screwdriver.
Remove the three silver screws (one 2 mm screw and two 4 mm screws) holding down the fan using a Phillips #0 screwdriver.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Unplug the fan’s power cord from the motherboard.
Remove the four gray 3 mm screws around the heat sink using a Phillips #0 screwdriver.
Remove the heat sink.
Using a Phillips #0 screwdriver, remove the three black 5 mm screws holding down the speaker:
Two screws on the left side
One screw on the right side
Unplug the speaker wire.
Remove the single 6 mm screw holding down the SSD using a Phillips #0 screwdriver.
Remove the five 3 mm gray screws from around the motherboard using a Phillips #00 screwdriver.
Unplug the wire connections.
Remove the four black 5 mm screws holding down the two silver screen hinges using a Phillips #00 screwdriver.
Unplug the screen from the motherboard by lifting the wire cover and removing the screen cord.
Separate the hinges from the computer.
Use an iFixit opening tool to remove all the plastic hold downs from the keyboard cover.
Remove all remaining plastic hold downs on the main keyboard with an iFixit opening tool.
