Zum Hauptinhalt wechseln
HP 14-fq1025nr Speakers Replacement
Was du brauchst
  1. HP 14-fq1025nr Speakers Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Flip the laptop upside down so the bottom cover is facing up.
  2. HP 14-fq1025nr Speakers Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a pair of tweezers to grab and pull the feet off of the cover.
  3. HP 14-fq1025nr Speakers Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 4 mm screws using a Phillips #0 screwdriver.
    • Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
  4. HP 14-fq1025nr Speakers Replacement: Schritt 4, Bild 1 von 1
    • Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
  5. HP 14-fq1025nr Speakers Replacement: Schritt 5, Bild 1 von 1
    • Remove the bottom cover.
  6. HP 14-fq1025nr Speakers Replacement, Fan: Schritt 6, Bild 1 von 1
    • Remove the three silver screws (one 2 mm screw and two 4 mm screws) holding down the fan using a Phillips #0 screwdriver.
  7. HP 14-fq1025nr Speakers Replacement: Schritt 7, Bild 1 von 1
    Kaufen
    • Unplug the fan’s power cord from the motherboard.
    • Use tweezers to pull the plug out, if needed.
  8. HP 14-fq1025nr Speakers Replacement: Schritt 8, Bild 1 von 1
    • Remove the fan.
  9. HP 14-fq1025nr Speakers Replacement, Heat Sink: Schritt 9, Bild 1 von 1
    • Remove the four gray 3 mm screws around the heat sink using a Phillips #0 screwdriver.
    • Remove the heat sink.
  10. HP 14-fq1025nr Speakers Replacement, Speakers: Schritt 10, Bild 1 von 2 HP 14-fq1025nr Speakers Replacement, Speakers: Schritt 10, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the three black 5 mm screws holding down the speaker:
    • Two screws on the left side
    • One screw on the right side
  11. HP 14-fq1025nr Speakers Replacement: Schritt 11, Bild 1 von 1
    Kaufen
    • Unplug the speaker wire.
    • Use tweezers if needed.
  12. HP 14-fq1025nr Speakers Replacement: Schritt 12, Bild 1 von 1
    • Remove the speaker.
Abschluss
Nil Parra
485 Reputation
4 Anleitungen geschrieben
Utah Tech University, Team 1-6, McMurrin Fall 2022 Mitglied von Utah Tech University, Team 1-6, McMurrin Fall 2022
UTAHTECH-MCMURRIN-F22S1G6
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 85
