Zum Hauptinhalt wechseln
HP 15-AF131DX Hard Drive Replacement
Was du brauchst
  1. HP 15-AF131DX Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 2 HP 15-AF131DX Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 2
    • Use a Phillips screwdriver to remove the 10 visible screws on the bottom.
    • Peel up the rubber feet near the hinges.
    • Remove the screw under each.
  2. HP 15-AF131DX Hard Drive Replacement: Schritt 2, Bild 1 von 2 HP 15-AF131DX Hard Drive Replacement: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Turn the computer over and use a plastic card, opening pick, or opening tool to pry the space between the keyboard and bottom surface of the computer.
    • Work plastic card, opening pick, or opening tool carefully around the three edges (excluding the side with the screen, which should be positioned at 90 degrees.
    • Gently lift the top surface of the bottom half of the laptop, revealing the hard drive.
  3. HP 15-AF131DX Hard Drive Replacement: Schritt 3, Bild 1 von 3 HP 15-AF131DX Hard Drive Replacement: Schritt 3, Bild 2 von 3 HP 15-AF131DX Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Remove the three screws that hold the hard drive in place.
    • Lift the hard drive slightly and disconnect the SATA hard drive connector to free the hard drive.
    • Remove the hard drive.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S6-G2, Banghart Fall 2017 Mitglied von Cal Poly, Team S6-G2, Banghart Fall 2017
CPSU-BANGHART-F17S6G2
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 25
Insgesamt: 5,384
