Zum Hauptinhalt wechseln
HP 15-AF131DX Wireless Network Card Replacement
Was du brauchst
  1. HP 15-AF131DX Wireless Network Card Replacement, Battery: Schritt 1, Bild 1 von 2 HP 15-AF131DX Wireless Network Card Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the computer upside down on a level surface.
    • Slide the battery lock to unlock the battery.
    • Slide the battery release latch. The latch will click when the battery is released.
    • Lift the battery from the middle to remove it from the computer.
    • The latch will click again when a battery is reinstalled. Switch the battery lock back to locked after reinstalling a battery to keep it secure.
  2. HP 15-AF131DX Wireless Network Card Replacement, Optical Drive: Schritt 2, Bild 1 von 2 HP 15-AF131DX Wireless Network Card Replacement, Optical Drive: Schritt 2, Bild 2 von 2
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  3. HP 15-AF131DX Wireless Network Card Replacement: Schritt 3, Bild 1 von 1
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  4. HP 15-AF131DX Wireless Network Card Replacement: Schritt 4, Bild 1 von 3 HP 15-AF131DX Wireless Network Card Replacement: Schritt 4, Bild 2 von 3 HP 15-AF131DX Wireless Network Card Replacement: Schritt 4, Bild 3 von 3
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
  5. HP 15-AF131DX Wireless Network Card Replacement, Wireless Network Card: Schritt 5, Bild 1 von 2 HP 15-AF131DX Wireless Network Card Replacement, Wireless Network Card: Schritt 5, Bild 2 von 2
    • The first step of this process is to peel off two rubber feet from the bottom of the laptop.
    • Then remove twelve 8.8 mm screws using the Phillips #0 Screwdriver.
  6. HP 15-AF131DX Wireless Network Card Replacement: Schritt 6, Bild 1 von 3 HP 15-AF131DX Wireless Network Card Replacement: Schritt 6, Bild 2 von 3 HP 15-AF131DX Wireless Network Card Replacement: Schritt 6, Bild 3 von 3
    • Remove the bottom of the plastic case using a blue plastic opening tool.
    • The HP Wireless Network Card is found in Picture 3, circled in red.
  7. HP 15-AF131DX Wireless Network Card Replacement: Schritt 7, Bild 1 von 3 HP 15-AF131DX Wireless Network Card Replacement: Schritt 7, Bild 2 von 3 HP 15-AF131DX Wireless Network Card Replacement: Schritt 7, Bild 3 von 3
    • Remove one 3.3 mm screw using Phillips #0 screwdriver.
    • Pop off the connection wire by pulling the wire upwards off the stud on the HP Wireless Network Card.
    • Pull out the HP Wireless Network Card.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
IUPUI, Team S2-G2, Harley Fall 2018 Mitglied von IUPUI, Team S2-G2, Harley Fall 2018
IUPUI-HARLEY-F18S2G2
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 620
