Einleitung
The guide will detail the replacement of the back panel of the HP 15-BA078DX.
Was du brauchst
Unclip the two latches on the bottom of the laptop.
Slide the battery straight out while holding the clip open.
Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Thank you so much! I know I am probably the only or one of the few people to write a comment for this specific laptop but I wanted to upgrade the RAM and HDD to SSD. Have a great day
