Zum Hauptinhalt wechseln
HP 15-BA078DX RAM Replacement
Was du brauchst
  1. HP 15-BA078DX RAM Replacement, Battery: Schritt 1, Bild 1 von 3 HP 15-BA078DX RAM Replacement, Battery: Schritt 1, Bild 2 von 3 HP 15-BA078DX RAM Replacement, Battery: Schritt 1, Bild 3 von 3
    • Unclip the two latches on the bottom of the laptop.
    • Slide the battery straight out while holding the clip open.
  2. HP 15-BA078DX RAM Replacement, Disc Drive: Schritt 2, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
  3. HP 15-BA078DX RAM Replacement: Schritt 3, Bild 1 von 3 HP 15-BA078DX RAM Replacement: Schritt 3, Bild 2 von 3 HP 15-BA078DX RAM Replacement: Schritt 3, Bild 3 von 3
    • Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
  4. HP 15-BA078DX RAM Replacement, Back Panel: Schritt 4, Bild 1 von 1
    • Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
    • Remember to remove the two screws under the rubber feet.
  5. HP 15-BA078DX RAM Replacement: Schritt 5, Bild 1 von 3 HP 15-BA078DX RAM Replacement: Schritt 5, Bild 2 von 3 HP 15-BA078DX RAM Replacement: Schritt 5, Bild 3 von 3
    • Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart.
    • You may need to flip the laptop over to unlatch all of the internal clips.
  6. HP 15-BA078DX RAM Replacement: Schritt 6, Bild 1 von 3 HP 15-BA078DX RAM Replacement: Schritt 6, Bild 2 von 3 HP 15-BA078DX RAM Replacement: Schritt 6, Bild 3 von 3
    • Carefully pull the shell of the computer apart.
  7. HP 15-BA078DX RAM Replacement, RAM: Schritt 7, Bild 1 von 2 HP 15-BA078DX RAM Replacement, RAM: Schritt 7, Bild 2 von 2
    • Using a plastic spudger, unclip the latch locking the RAM to the motherboard.
  8. HP 15-BA078DX RAM Replacement: Schritt 8, Bild 1 von 3 HP 15-BA078DX RAM Replacement: Schritt 8, Bild 2 von 3 HP 15-BA078DX RAM Replacement: Schritt 8, Bild 3 von 3
    • Gently tilt the RAM sticks up and slide out each stick.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team S3-G4, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G4, Peak Spring 2018
UMASSD-PEAK-S18S3G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 534
