Einleitung
This guide will detail the removal of the onboard Random Access Memory (RAM) modules that are installed in the laptop.
Was du brauchst
Unclip the two latches on the bottom of the laptop.
Slide the battery straight out while holding the clip open.
Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart.
Using a plastic spudger, unclip the latch locking the RAM to the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
