Einleitung
This guide will detail the process of replacing the Touchscreen from the HP 15-BA078DX laptop.
Was du brauchst
Unclip the two latches on the bottom of the laptop.
Slide the battery straight out while holding the clip open.
Carefully use the blue plastic opening tool to remove the outer frame of the screen.
Flip the laptop on its back.
Detach the bottom section of the screen frame from the laptop by using the black nylon spudger.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
