Zum Hauptinhalt wechseln
HP 15-R011DX RAM (Random Access Memory) Replacement
Was du brauchst
  1. HP 15-R011DX RAM (Random Access Memory) Replacement, Battery: Schritt 1, Bild 1 von 2 HP 15-R011DX RAM (Random Access Memory) Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide the lock mechanism on the left side of the laptop to the right.
  2. HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 2, Bild 1 von 1
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
  3. HP 15-R011DX RAM (Random Access Memory) Replacement, How to Access the Internal Components of an HP 15-R011DX: Schritt 3, Bild 1 von 2 HP 15-R011DX RAM (Random Access Memory) Replacement, How to Access the Internal Components of an HP 15-R011DX: Schritt 3, Bild 2 von 2
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
  4. HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 4, Bild 1 von 2 HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 4, Bild 2 von 2
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
  5. HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 5, Bild 1 von 2 HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 5, Bild 2 von 2
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
  6. HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 6, Bild 1 von 3 HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 6, Bild 2 von 3 HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 6, Bild 3 von 3
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
  7. HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 7, Bild 1 von 2 HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
  8. HP 15-R011DX RAM (Random Access Memory) Replacement, Hard Drive: Schritt 8, Bild 1 von 1
    • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
  9. HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 9, Bild 1 von 2 HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 9, Bild 2 von 2
    • Pull the hard drive upwards and away from the laptop.
    • The hard drive should disconnect from its port on the motherboard as shown in the second image.
  10. HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 10, Bild 1 von 1
    • Flip the hard drive over.
    • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
    • Remove the mounting brace (silver bracket) from the hard drive.
  11. HP 15-R011DX RAM (Random Access Memory) Replacement, Motherboard: Schritt 11, Bild 1 von 2 HP 15-R011DX RAM (Random Access Memory) Replacement, Motherboard: Schritt 11, Bild 2 von 2
    • Remove the remaining two 5 mm Philips #1 screws from the motherboard.
  12. HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 12, Bild 1 von 1
    • Remove the tape from the display connector attached to the motherboard.
    • Disconnect the display connector from the motherboard.
  13. HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 13, Bild 1 von 1
    • Remove one 4 mm Phillips #1 screw from the wireless chip.
    • Remove the wireless chip from the motherboard.
  14. HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 14, Bild 1 von 1
    • Remove two 5 mm Phillips #1 screws from the USB component connected to the motherboard.
    • Lift the USB component until the band connecting it to the motherboard lifts off of the laptop.
  15. HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 15, Bild 1 von 1
    • Slowly lift the motherboard out of the computer.
    • Be sure that the I/O ports on the left side of the motherboard are not stuck on the laptop frame.
    • Disconnect the power connector from the motherboard as shown in the image.
  16. HP 15-R011DX RAM (Random Access Memory) Replacement, RAM (Random Access Memory): Schritt 16, Bild 1 von 1
    • Locate the RAM drive on the underside of the motherboard.
  17. HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 17, Bild 1 von 2 HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 17, Bild 2 von 2
    • Push the locking tabs outward to release the RAM chip from the motherboard.
  18. HP 15-R011DX RAM (Random Access Memory) Replacement: Schritt 18, Bild 1 von 1
    • Remove the RAM chip by pulling the drive from the connectors.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team S2-G4, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S2-G4, Bailey Spring 2019
UMASSD-BAILEY-S19S2G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 1,374
