Zum Hauptinhalt wechseln
Einleitung
Use this guide to replace the back panel of your device.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Locate the CD Compartment panel and gently slide it out. Locate the CD Compartment panel and gently slide it out. Locate the CD Compartment panel and gently slide it out.
    • Locate the CD Compartment panel and gently slide it out.
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. Remove the back of the laptop by unscrewing the screws shown.
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  4. Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off. Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed! Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Ashton Martin
372 Reputation
2 Anleitungen geschrieben
Baylor, Team S1-G2, Johnson Spring 2018 Mitglied von Baylor, Team S1-G2, Johnson Spring 2018
BU-JOHNSON-S18S1G2
3 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 30
Insgesamt: 468
