Einleitung
Does the case of your laptop have scratches, dents, or you just want to do a deep clean? Well, then this is the guide for you. This guide will direct you through the steps to removing the back panel of an HP15-AC121DX. Doing this will reveal the heart and soul of your computer allowing you to replace more than just the case, and ensure your electronics are dust-free.
Was du brauchst
Remove all external devices from the computer.
Remove the charging cord from the computer.
To remove the battery, slide the left slider on the back to the unlocked position.
Push the right slider inwards.
Remove the battery out by pulling straight out and to the right.
Place the laptop with the back panel facing up and the battery compartment facing away from you.
Using a spudger, carefully remove the rubber feet on both sides of the battery compartment.
Using a Phillips #000 screwdriver, remover the ten 7mm screws on the back panel.
Using the same screwdriver, remove the two 5mm Phillips #000 screws on both sides of the battery compartment.
With the same orientation as the previous step, locate the bottom left corner.
Using a plastic opening tool, carefully pry off and remove the back panel.
2 weitere Personen haben diese Anleitung absolviert.
