Einleitung
This guide will teach you how to replace the CD Compartment. You will need plastic prying tools and a Phillips J001 screw driver.
Was du brauchst
Remove all external devices from the computer.
Remove the charging cord from the computer.
To remove the battery, slide the left slider on the back to the unlocked position.
Push the right slider inwards.
Remove the battery out by pulling straight out and to the right.
Remove the back of the laptop by unscrewing the screws shown.
Also remove the other 5 Phillips screws lining the back cover.
Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
Replace CD compartment. To reassemble your device, follow these instructions in reverse order.
4 weitere Personen haben diese Anleitung absolviert.
