Einleitung
This guide will teach you how to replace the broken fan in your HP 15-ac121dx laptop to prevent the device from overheating.
Was du brauchst
Remove all external devices from the computer.
Remove the charging cord from the computer.
To remove the battery, slide the left slider on the back to the unlocked position.
Push the right slider inwards.
Remove the battery out by pulling straight out and to the right.
Remove the back of the laptop by unscrewing the screws shown.
Also remove the other 5 Phillips screws lining the back cover.
Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
Locate the Fan as shown.
Pull out the black cable, with four wires attached from its port.
Pull out the white cable wire from its port.
Unscrew the two black Phillips screws holding in the fan.
Replace fan. To reassemble your device, follow these instructions in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
