Einleitung
This Guide will walk you through replacing your keyboard on a HP 15-ac121dx Laptop. This is not an easy process, so you will want to pull out your plastic prying tools and Philips J00 Screw Driver and follow the instructions closely.
  1. Remove all external devices from the computer.
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. Turn off the computer by holding the power button.
    • Turn off the computer by holding the power button.
    • To remove the battery, slide the left slider on the back to the unlocked position.
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
    • Locate the CD Compartment panel and gently slide it out.
    • Remove the back of the laptop by unscrewing the screws shown.
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Locate the CD Compartment as shown and gently slide it out.
    • Locate the Fan as shown.
    • Pull out the black cable, with four wires attached from its port.
    • Pull out the white cable wire from its port.
    • Remove fan.
    • Remove the 3mm screws.
    • Remove the 9mm screw.
    • Locate the four ribbon clips.
    • Lift the grey part of the ribbon clips.
    • Pull the ribbon cable out and repeat this step for all four ribbon cables.
    • Pull out the white cable (contains red and white cable attached to a black support) with wires from its port.
    • Remove the motherboard.
    • Remove the CPU.
    • Lift up the cable port and place it to the side but do not remove completely from the laptop.
    • Remove the VENDOR component.
    • Using a plastic prying tools, remove the grey metal plate.
    • Locate the damaged keyboard and lift up with the prying tool to remove.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Onose Aigbe
Mitglied seit 30.01.2018
390 Reputation
3 Anleitungen geschrieben
Baylor, Team S1-G2, Johnson Spring 2018 Mitglied von Baylor, Team S1-G2, Johnson Spring 2018
BU-JOHNSON-S18S1G2
3 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 71
Insgesamt: 523
