Zum Hauptinhalt wechseln
HP 15-ac121dx Wifi Card Replacement
Was du brauchst
  1. HP 15-ac121dx Wifi Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Wifi Card Replacement: Schritt 2, Bild 1 von 1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Wifi Card Replacement: Schritt 3, Bild 1 von 2 HP 15-ac121dx Wifi Card Replacement: Schritt 3, Bild 2 von 2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Wifi Card Replacement: Schritt 4, Bild 1 von 2 HP 15-ac121dx Wifi Card Replacement: Schritt 4, Bild 2 von 2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Wifi Card Replacement, Back Panel: Schritt 5, Bild 1 von 2 HP 15-ac121dx Wifi Card Replacement, Back Panel: Schritt 5, Bild 2 von 2
    • Place the laptop with the back panel facing up and the battery compartment facing away from you.
    • Using a spudger, carefully remove the rubber feet on both sides of the battery compartment.
  6. HP 15-ac121dx Wifi Card Replacement: Schritt 6, Bild 1 von 1
    • Using a Phillips #000 screwdriver, remover the ten 7mm screws on the back panel.
    • Using the same screwdriver, remove the two 5mm Phillips #000 screws on both sides of the battery compartment.
  7. HP 15-ac121dx Wifi Card Replacement: Schritt 7, Bild 1 von 1
    • With the same orientation as the previous step, locate the bottom left corner.
    • Using a plastic opening tool, carefully pry off and remove the back panel.
  8. HP 15-ac121dx Wifi Card Replacement, Wifi Card: Schritt 8, Bild 1 von 3 HP 15-ac121dx Wifi Card Replacement, Wifi Card: Schritt 8, Bild 2 von 3 HP 15-ac121dx Wifi Card Replacement, Wifi Card: Schritt 8, Bild 3 von 3
    • With the back panel removed, orient the laptop with the fan located in the bottom left corner.
    • Locate the Wifi card.
    • Using a Phillips #000 screwdriver, remove the 2mm screw securing the Wifi card in place.
    • Carefully remove the Wifi card.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 372
