Einleitung
Motherboard is like a brain to a computer. It controlls the computer and makes it run smoothly based on the quality of motherboard on the device. This important component is charged through the little circular shiny batteries. This guide is on how to remove those batteries and replace them with new ones.
Was du brauchst
Turn off the computer and flip it over onto a flat surface.
Remove battery by sliding the battery lock.
Remove the 10 screws
Flip the computer back over and use the iFixit tool in order to pry the keyboard from the bottom of the computer.
Once off you will be able to see the mother board battery.
Remove the battery.
Follow previous instructions in reverse order to reassemble the device .
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
