Einleitung
Project title: How to Replace a Keyboard on an HP Pavilion Series Laptop
Included:
- Checkpoint photo set (PDF, steps 1–8): 4 completed, hands-on photos (my HP Pavilion and my hand in frame) and labeled placeholders for the final four shots I’ll add after approval.
📄 iFixit_Checkpoint_Photo_Set_Nancy_Forvilus-Corvil.pdf - (Optional supporting docs for your records)
• 📄 Fast Fix Project Proposal
• 📄 Full iFixit Project – HP Pavilion Keyboard
What the attached photos show (Steps 1–4 completed):
- Powering down and unplugging the HP Pavilion
- Flipping the laptop to access the bottom panel/battery area
- Identifying bottom-panel screws and battery latch
- Setting up the work area and parts tray
I plan to add the remaining shots (panel off, ribbon-cable unlock/lock, and final key test) immediately after checkpoint approval. Please let me know if these meet the EDU requirements or if you’d like any adjustments before I proceed.
Thank you for your time!
Was du brauchst
Remove all external devices from the computer.
Remove the charging cord from the computer.
To remove the battery, slide the left slider on the back to the unlocked position.
Push the right slider inwards.
Remove the battery out by pulling straight out and to the right.
Remove the back of the laptop by unscrewing the screws shown.
Also remove the other 5 Phillips screws lining the back cover.
Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
Locate the Fan as shown.
Pull out the black cable, with four wires attached from its port.
Pull out the white cable wire from its port.
Unscrew the two black Phillips screws holding in the fan.
Locate the four ribbon clips.
Lift the grey part of the ribbon clips.
Pull the ribbon cable out and repeat this step for all four ribbon cables.
Also use a spudger and release the TWO cables attaching the hard drive to the motherboard. Another ribbon cable is located where the fan was sitting.
Pull out the white cable (contains red and white cable attached to a black support) with wires from its port.
Lift up the cable port and place it to the side but do not remove completely from the laptop.
Remove the single Phillips screw securing it first.
Remove the VENDOR component.
Unscrew the single Phillips screw holding it to the frame first.
Using a plastic prying tools, remove the grey metal plate.
It will not come off easy, but do not force it off.
To put everything back together and use your laptop with the new keyboard, follow the steps in REVERSE..
ENJOY :)
7 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
Did you have to use soldering iron to melt the plastic rivets when putting back the keyboard?
Cheers.
I have done these before and yes, using a soldering iron to melt the plastic rivets is a good method.
Helpful. Too good!
