Zum Hauptinhalt wechseln
HP 15-af013cl AC Adapter Replacement
Was du brauchst
  1. HP 15-af013cl AC Adapter Replacement, Battery: Schritt 1, Bild 1 von 1
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl AC Adapter Replacement: Schritt 2, Bild 1 von 3 HP 15-af013cl AC Adapter Replacement: Schritt 2, Bild 2 von 3 HP 15-af013cl AC Adapter Replacement: Schritt 2, Bild 3 von 3
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl AC Adapter Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Using the Phillips P0 screwdriver, remove the nine 2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional two 2.0mm × 1.5mm Phillips screws located in the battery compartment.
  4. HP 15-af013cl AC Adapter Replacement: Schritt 4, Bild 1 von 2 HP 15-af013cl AC Adapter Replacement: Schritt 4, Bild 2 von 2
    • Remove the optical disk drive from the side of the laptop.
  5. HP 15-af013cl AC Adapter Replacement: Schritt 5, Bild 1 von 1
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
  6. HP 15-af013cl AC Adapter Replacement: Schritt 6, Bild 1 von 2 HP 15-af013cl AC Adapter Replacement: Schritt 6, Bild 2 von 2
    • Begin by removing the 3 Phillips M2.0mm × 10.0mm screws of the processor fan.
    • Disconnect the fan connector from the motherboard.
  7. HP 15-af013cl AC Adapter Replacement: Schritt 7, Bild 1 von 1
    • Remove the five Phillips 2.5mm × 6 .5mm screws using the Phillips P0 screwdriver.
  8. HP 15-af013cl AC Adapter Replacement: Schritt 8, Bild 1 von 3 HP 15-af013cl AC Adapter Replacement: Schritt 8, Bild 2 von 3 HP 15-af013cl AC Adapter Replacement: Schritt 8, Bild 3 von 3
    • Disconnect the ribbon cables for the keyboard, display, trackpad and the various system components.
    • Remove the Wi-Fi card and cables.
  9. HP 15-af013cl AC Adapter Replacement: Schritt 9, Bild 1 von 1
    • Carefully lift out the motherboard from the laptop.
  10. HP 15-af013cl AC Adapter Replacement, AC Adapter: Schritt 10, Bild 1 von 1
    • Remove the 2 M2.0mm × 5.0mm Phillips screws located on the metal screen hinge closest to where the processor fan was.
  11. HP 15-af013cl AC Adapter Replacement: Schritt 11, Bild 1 von 3 HP 15-af013cl AC Adapter Replacement: Schritt 11, Bild 2 von 3 HP 15-af013cl AC Adapter Replacement: Schritt 11, Bild 3 von 3
    • Lift off the metal hinge from the laptop body.
    • Gently pull up on the cable leading to the charging port.
Abschluss
Cal Poly, Team S8-G6, Banghart Fall 2017 Mitglied von Cal Poly, Team S8-G6, Banghart Fall 2017
CPSU-BANGHART-F17S8G6
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 680
