Zum Hauptinhalt wechseln
HP 15-af123cl Hard Drive Replacement
Was du brauchst
  1. HP 15-af123cl Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 HP 15-af123cl Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push the slider with a lock symbol to the right to unlock the battery.
  2. HP 15-af123cl Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Push the slider with a battery symbol to the left to push the battery out slightly.
    • Pull the battery out fully now that it is released.
  3. HP 15-af123cl Hard Drive Replacement, Back Cover: Schritt 3, Bild 1 von 1
    • Remove the twelve screws from the bottom of the laptop using a Phillips #00 screwdriver.
  4. HP 15-af123cl Hard Drive Replacement: Schritt 4, Bild 1 von 3 HP 15-af123cl Hard Drive Replacement: Schritt 4, Bild 2 von 3 HP 15-af123cl Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Turn the laptop over and open the lid.
    • Use an opening tool to pry the bottom cover from the body of the laptop.
  5. HP 15-af123cl Hard Drive Replacement: Schritt 5, Bild 1 von 2 HP 15-af123cl Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Close and turn over the laptop again.
    • Pull the back cover up to remove it from the laptop.
  6. HP 15-af123cl Hard Drive Replacement, Hard Drive: Schritt 6, Bild 1 von 2 HP 15-af123cl Hard Drive Replacement, Hard Drive: Schritt 6, Bild 2 von 2
    • Unclip the cable connected to the drive using an opening tool.
  7. HP 15-af123cl Hard Drive Replacement: Schritt 7, Bild 1 von 3 HP 15-af123cl Hard Drive Replacement: Schritt 7, Bild 2 von 3 HP 15-af123cl Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Remove the screws from the brackets around the hard drive using a Phillips #00 screwdriver.
  8. HP 15-af123cl Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Remove the brackets from around the hard drive.
    • Remove the hard drive from the laptop.
Abschluss
UMass Dartmouth, Team 2-5, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 2-5, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 426
