Was du brauchst
Slide the two battery lock latches on the back of the device to the “unlock” position.
Using the PH1 phillips-head screwdriver, remove all the 5/16 in. screws from the back of the device.
Locate the optical disc drive and remove it from the device by sliding it straight of the device.
Covering the hinges of the device are rubber bumpers secured to the device using adhesive. Remove them carefully.
In the same spot you’ve just removed the bumpers from, you will find two 5/16 in. screws. Using the same Phillips-head screwdriver used in step 2, remove the screws
There are two 5/16 in. screws adjacent from each other that secure the fan to the device. Use the PH1 phillips-head screwdriver to remove them.
Lift the clear plastic strip holding down the fan and lift the fan out of place.
Use your fingers or tweezers to pinch both sides of the connector and remove the fan from the device.
Eine weitere Person hat diese Anleitung absolviert.
