Zum Hauptinhalt wechseln
HP 15-ay014dx Hard Drive Disk Replacement
Was du brauchst
  1. HP 15-ay014dx Hard Drive Disk Replacement, Battery: Schritt 1, Bild 1 von 1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Hard Drive Disk Replacement: Schritt 2, Bild 1 von 1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Hard Drive Disk Replacement: Schritt 3, Bild 1 von 1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Hard Drive Disk Replacement, Optical Drive: Schritt 4, Bild 1 von 1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Hard Drive Disk Replacement: Schritt 5, Bild 1 von 1
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: Schritt 6, Bild 1 von 2 HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: Schritt 6, Bild 2 von 2
    • Remove the highlighted screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx Hard Drive Disk Replacement: Schritt 7, Bild 1 von 3 HP 15-ay014dx Hard Drive Disk Replacement: Schritt 7, Bild 2 von 3 HP 15-ay014dx Hard Drive Disk Replacement: Schritt 7, Bild 3 von 3
    • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
    • Pull the back cover off.
  8. HP 15-ay014dx Hard Drive Disk Replacement: Schritt 8, Bild 1 von 3 HP 15-ay014dx Hard Drive Disk Replacement: Schritt 8, Bild 2 von 3 HP 15-ay014dx Hard Drive Disk Replacement: Schritt 8, Bild 3 von 3
    • Pry up on the clamp holding the SATA power ribbon using the plastic opening tool.
    • Pull out the SATA power ribbon using the tweezers.
  9. HP 15-ay014dx Hard Drive Disk Replacement: Schritt 9, Bild 1 von 2 HP 15-ay014dx Hard Drive Disk Replacement: Schritt 9, Bild 2 von 2
    • Remove the highlighted screws holding the hard drive to the body using the Philips #00 screwdriver.
    • Remove the hard drive.
  10. HP 15-ay014dx Hard Drive Disk Replacement: Schritt 10, Bild 1 von 1
    • Remove the 4 screws holding the hard drive to the hard drive cage using the Philips #00 screwdriver.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Jimmy Huynh
263 Reputation
1 Anleitung geschrieben
Washington State, Team S1-G4, Phelps-Hillen Fall 2017 Mitglied von Washington State, Team S1-G4, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S1G4
6 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 1,921
