Einleitung
This guide will provide simple, easy to follow instructions for replacing the Hard Drive Disk for HP-15ay014dx
Was du brauchst
With the device turned upside down, use your index fingers to push the battery latches in towards each other.
Close the laptop and lay it down with the bottom facing up.
Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
Remove the highlighted screws holding the body of the laptop together with a size #00 Phillips screwdriver.
Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
Pull the back cover off.
Pry up on the clamp holding the SATA power ribbon using the plastic opening tool.
Pull out the SATA power ribbon using the tweezers.
Remove the highlighted screws holding the hard drive to the body using the Philips #00 screwdriver.
Remove the hard drive.
Remove the 4 screws holding the hard drive to the hard drive cage using the Philips #00 screwdriver.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
