Einleitung
This guide will teach you how to safely remove the heat sink on a HP 15-ay014dx laptop for maintenance or replacement.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Disconnect device from power source and power down.
    • Disconnect device from power source and power down.
  2. With the device turned upside down, use your index fingers to push the battery latches in towards each other.
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. Close the laptop and lay it down with the bottom facing up.
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Grip the optical drive and gently pull it out.
    • Grip the optical drive and gently pull it out.
  7. Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
    • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  8. Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body. Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
    • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
  9. Using the spudger, carefully pry the wire connecting the wireless card to the motherboard off of it. Using the spudger, carefully pry the wire connecting the wireless card to the motherboard off of it.
    • Using the spudger, carefully pry the wire connecting the wireless card to the motherboard off of it.
  10. Using the size #00 Phillips screwdriver remove the single screw holding it in place.
    • Using the size #00 Phillips screwdriver remove the single screw holding it in place.
  11. carefully pull the card of its slot.
    • carefully pull the card of its slot.
  12. Remove the four screws holding the heatsink on.
    • Remove the four screws holding the heatsink on.
  13. Carefully pry the heat sink up and out of position to un-stick it from the thermal paste.
Abschluss
Drake Scoville
476 Reputation
4 Anleitungen geschrieben
Washington State, Team S1-G4, Phelps-Hillen Fall 2017 Mitglied von Washington State, Team S1-G4, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S1G4
6 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 137
