Einleitung
This guide will show you how to safely remove the RAM in your HP 15-ay014dx laptop for replacement.
Was du brauchst
With the device turned upside down, use your index fingers to push the battery latches in towards each other.
Close the laptop and lay it down with the bottom facing up.
Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
Use the spudger to press the tabs in the back of the computer. Carefully remove the back of the laptop by prying around the sides using the plastic opening tool.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
