Einleitung
This guide will aid users in removing and replacing the fan of their HP 15-ay091ms Device. A malfunctioning fan can damage the device over time; a working fan helps to avoid overheating. Removal and replacement of the fan is an easy fix users can do to protect the longevity of their device.
Was du brauchst
Push the latches on either side of the battery down and outward.
Remove the battery.
Remove the screws from the bottom panel using a JIS #0 screwdriver.
Use the iFixit opening pick to lift the back cover from the device.
