Zum Hauptinhalt wechseln
HP 15-ay091ms Optical Disk Drive Replacement
Was du brauchst
  1. HP 15-ay091ms Optical Disk Drive Replacement, Battery: Schritt 1, Bild 1 von 2 HP 15-ay091ms Optical Disk Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Ensure the device is powered off and is disconnected from any AC power supply.
    • Push the latches on either side of the battery down and outward.
    • This unlatches the battery allowing for easy removal.
    • Remove the battery.
  2. HP 15-ay091ms Optical Disk Drive Replacement, Back Panel: Schritt 2, Bild 1 von 3 HP 15-ay091ms Optical Disk Drive Replacement, Back Panel: Schritt 2, Bild 2 von 3 HP 15-ay091ms Optical Disk Drive Replacement, Back Panel: Schritt 2, Bild 3 von 3
    • Remove the screws from the bottom panel using a JIS #0 screwdriver.
    • Use the iFixit opening pick to lift the back cover from the device.
    • It is helpful to get an opening in one spot of the back cover and carry that opening around the device.
  3. HP 15-ay091ms Optical Disk Drive Replacement, Optical Disk Drive: Schritt 3, Bild 1 von 3 HP 15-ay091ms Optical Disk Drive Replacement, Optical Disk Drive: Schritt 3, Bild 2 von 3 HP 15-ay091ms Optical Disk Drive Replacement, Optical Disk Drive: Schritt 3, Bild 3 von 3
    • Remove the screws holding the optical drive in place using a JIS #0 screwdriver.
    • Pull the optical disk drive out of its slot.
Abschluss
Gateway, Team A-1, Gonzalez Fall 2023 Mitglied von Gateway, Team A-1, Gonzalez Fall 2023
GCC-GONZALEZ-F23SAG1
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 8
Letzte 30 Tage: 11
Insgesamt: 93
