Zum Hauptinhalt wechseln
HP 15-ay103dx Back Panel Replacement
Was du brauchst
  1. HP 15-ay103dx Back Panel Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the two battery lock latches on the back of the device to the “unlock” position.
  2. HP 15-ay103dx Back Panel Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery upward to remove it from the device.
  3. HP 15-ay103dx Back Panel Replacement, Back Panel: Schritt 3, Bild 1 von 1
    • Using the PH1 phillips-head screwdriver, remove all the 5/16 in. screws from the back of the device.
    • There should be 10 in total, be sure to keep them together!
  4. HP 15-ay103dx Back Panel Replacement: Schritt 4, Bild 1 von 1
    • Locate the optical disc drive and remove it from the device by sliding it straight of the device.
  5. HP 15-ay103dx Back Panel Replacement: Schritt 5, Bild 1 von 2 HP 15-ay103dx Back Panel Replacement: Schritt 5, Bild 2 von 2
    • Covering the hinges of the device are rubber bumpers secured to the device using adhesive. Remove them carefully.
    • Place the adhesive side up as you will need to place them back after your replacement is complete.
  6. HP 15-ay103dx Back Panel Replacement: Schritt 6, Bild 1 von 2 HP 15-ay103dx Back Panel Replacement: Schritt 6, Bild 2 von 2
    • In the same spot you’ve just removed the bumpers from, you will find two 5/16 in. screws. Using the same Phillips-head screwdriver used in step 2, remove the screws
    • Be sure to keep the screws together!
  7. HP 15-ay103dx Back Panel Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove the back panel from the device.
    • If you are unable to do this with your hands, you can use a thin prying tool of your choice to make it easier!
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 1,511
