Was du brauchst
Slide the two battery lock latches on the back of the device to the “unlock” position.
Using the PH1 phillips-head screwdriver, remove all the 5/16 in. screws from the back of the device.
Locate the optical disc drive and remove it from the device by sliding it straight of the device.
Covering the hinges of the device are rubber bumpers secured to the device using adhesive. Remove them carefully.
In the same spot you’ve just removed the bumpers from, you will find two 5/16 in. screws. Using the same Phillips-head screwdriver used in step 2, remove the screws
Disconnect the wires around the motherboard securing it to the device.
Remove the six 5/16 in. screws holding the motherboard onto the device using the P1 philips-head screwdriver.
Disconnect the wire securing the whole motherboard located at the top to the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
