Einleitung
Use this guide to replace a dead hard drive.
  1. Use Latch on the left to unlock the battery
    • Use Latch on the left to unlock the battery
    • Use Latch on the right to eject the battery
  2. Remove case screws
    • Remove case screws
      • Ten 8mm Phillips #1
    • Use prying tool to remove optical drive
    • Use Uspudger to remove left and right rubber feet
    • Remove the screws located beneath both rubber feet.
      • Two 8mm Phillips #1
    • Use the prying tool to remove the bottom case.
      • Careful to not damage the clips that hold the bottom case on.
      • I found it easier to start on the opposite side of the hinges.
    • Remove screws securing the hard drive bracket
      • Three 3mm Phillips #0
    • Use spudger to loosen the SATA connector then disconnect the cable and remove the hard drive.
    • Remove bracket screws from the hard drive.
      • Four 3mm Phillips #1
      • Make sure, when reassembling, to orient the hard drive correctly in the brackets.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Joe Severino
Mitglied seit 07.11.2017
199 Reputation
1 Anleitung geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 57
