Zum Hauptinhalt wechseln
HP 15-ba0709dx Back Cover Replacement
Was du brauchst
  1. HP 15-ba0709dx Back Cover Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch on the left and right side until the battery is detached from its slot.
    • A noticeable pop will be heard when the battery is fully released.
  2. HP 15-ba0709dx Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery out of its slot.
    • Be careful not to damage any of the connectors in the process.
  3. HP 15-ba0709dx Back Cover Replacement, Back Cover: Schritt 3, Bild 1 von 1
    • Place the laptop on a clean, flat surface with the bottom side facing up.
  4. HP 15-ba0709dx Back Cover Replacement: Schritt 4, Bild 1 von 1
    • Using a Phillips Head Screwdriver, remove the screws anchoring the bottom casing.
    • Note: Make sure to keep track of the screws once they have been removed.
  5. HP 15-ba0709dx Back Cover Replacement: Schritt 5, Bild 1 von 1
    • Locate the screws about 1 inch from the battery release tabs and use a Phillips Head Screwdriver to remove these screws.
    • Note:Place these newly removed screws with the ones removed in Step 2.
  6. HP 15-ba0709dx Back Cover Replacement: Schritt 6, Bild 1 von 2 HP 15-ba0709dx Back Cover Replacement: Schritt 6, Bild 2 von 2
    • Locate the rubber friction pads on the top corners of the laptop. Pry the pads from the laptop and place them off to the side
    • Removing the friction pads will reveal two more anchoring screws.
    • Note: The adhesive keeping the pads on the laptop will weaken once doing this, but it is necessary to removing the bottom cover of the laptop.
  7. HP 15-ba0709dx Back Cover Replacement: Schritt 7, Bild 1 von 1
    • Remove disc reader.
    • Note: If all screws are removed it should slide out easily.
  8. HP 15-ba0709dx Back Cover Replacement: Schritt 8, Bild 1 von 2 HP 15-ba0709dx Back Cover Replacement: Schritt 8, Bild 2 von 2
    • Use a plastic prod to pry the back cover off the laptop.
    • Be careful not to damage the laptop while prying.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Lydia Brown
369 Reputation
2 Anleitungen geschrieben
Texas Tech, Team S13-G3, Bennett Spring 2017 Mitglied von Texas Tech, Team S13-G3, Bennett Spring 2017
TTU-BENNETT-S17S13G3
5 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Make sure to use a very thin shim, but strong enough to pry.
spotty118 - Antwort
thanks- also worked for 15-ba053nr
Renee Brandt - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 1,917
