Einleitung
Follow this guide to remove the back cover on HP 15-ba0709dx laptop. This guide is a prerequisite to practically every repair and replacement that this laptop requires.
Was du brauchst
Flip the device over and locate the battery compartment.
Slide the battery release latch on the left and right side until the battery is detached from its slot.
A noticeable pop will be heard when the battery is fully released.
Place the laptop on a clean, flat surface with the bottom side facing up.
Using a Phillips Head Screwdriver, remove the screws anchoring the bottom casing.
Locate the screws about 1 inch from the battery release tabs and use a Phillips Head Screwdriver to remove these screws.
Locate the rubber friction pads on the top corners of the laptop. Pry the pads from the laptop and place them off to the side
Removing the friction pads will reveal two more anchoring screws.
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare
thanks- also worked for 15-ba053nr
