Einleitung
If your device is heating up more than normal, consider following this guide to replace the heat sink in your device.
Was du brauchst
Remove battery
Remove the 12 visible screws from the back including 4 underneath rubber feet
Remove CD drive
Remove the backplate
Remove the 4 screws from the silver plate holding the heat sink onto the CPU
Remove the Heatsink from the CPU
Place a small bead of thermal paste on the CPU and place the new heatsink in place pressing it down
Tighten screws on heatsink and reassemble the computer
