Einleitung
If you’re looking to upgrade or replace the RAM in your laptop, consider using this guide to do so.
Was du brauchst
Remove the battery
Remove the 12 screws from the back plate including 4 screws that are under rubber feet
Remove CD drive
Remove back plate
Pull the silver latches away from the RAM
Once RAM is free it will spring up at an angle
Grab the RAM stick by the side and pull out of the socket
When inserting the RAM make sure to line up the notch on the RAM card with the pin on the port
Insert RAM until the gold contacts are no longer visible
Press down ram stick till it clicks in
