Was du brauchst
Remove the battery
Remove the 12 screws from the back plate including 4 screws underneath rubber feet.
Remove the backplate
Unplug webcam and WiFi cables (remove sticker from cable and pull horizontally)
Remove the screw for the fan and lift out of the way
Remove all screws from the hinges and lift them off of the Motherboard plate
Remove Screen from keyboard and motherboard tray
Using a flat tool separate the bezel from the screen housing
Remove the cable connected to the screen and replace with a new screen
Follow assembly in reverse
