Zum Hauptinhalt wechseln
HP 15-d076nr RAM Replacement
Was du brauchst
  1. HP 15-d076nr RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces away from you.
  2. HP 15-d076nr RAM Replacement: Schritt 2, Bild 1 von 1
    • Locate the small screw on the panel at the center of the laptop.
    • Loosen the small screw using a Philips # 1 screwdriver.
    • The screw does not come free from the panel. It only needs to be loosened enough so that the panel can be lifted/pried.
  3. HP 15-d076nr RAM Replacement: Schritt 3, Bild 1 von 2 HP 15-d076nr RAM Replacement: Schritt 3, Bild 2 von 2
    • Carefully pry the middle panel up using a plastic spudger or other prying tool .
    • Pull the panel away from the laptop and set it off to the side.
  4. HP 15-d076nr RAM Replacement: Schritt 4, Bild 1 von 1
    • Locate the RAM in the exposed area.
  5. HP 15-d076nr RAM Replacement: Schritt 5, Bild 1 von 3 HP 15-d076nr RAM Replacement: Schritt 5, Bild 2 von 3 HP 15-d076nr RAM Replacement: Schritt 5, Bild 3 von 3
    • Locate the latches on the RAM.
    • Slide the latches away from the RAM using a plastic spudger.
    • The RAM might spring out.
  6. HP 15-d076nr RAM Replacement: Schritt 6, Bild 1 von 1
    • Remove the RAM.
Abschluss
Amy Weed
577 Reputation
5 Anleitungen geschrieben
Oakland University, Team 2-2, Ruskiewicz Winter 2017 Mitglied von Oakland University, Team 2-2, Ruskiewicz Winter 2017
OAK-RUSKIEWICZ-W17S2G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 551
