Zum Hauptinhalt wechseln
HP 15-da0002dx SSD Replacement
Was du brauchst
  1. HP 15-da0002dx SSD Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx SSD Replacement: Schritt 2, Bild 1 von 1
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx SSD Replacement: Schritt 3, Bild 1 von 2 HP 15-da0002dx SSD Replacement: Schritt 3, Bild 2 von 2
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx SSD Replacement: Schritt 4, Bild 1 von 1
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx SSD Replacement: Schritt 5, Bild 1 von 1
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx SSD Replacement: Schritt 6, Bild 1 von 2 HP 15-da0002dx SSD Replacement: Schritt 6, Bild 2 von 2
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx SSD Replacement: Schritt 7, Bild 1 von 1
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
  8. HP 15-da0002dx SSD Replacement, Battery: Schritt 8, Bild 1 von 1
    • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
  9. HP 15-da0002dx SSD Replacement: Schritt 9, Bild 1 von 2 HP 15-da0002dx SSD Replacement: Schritt 9, Bild 2 von 2
    • Using your fingers, tilt the top part of the battery towards you.
    • Continue to pull the rest of the battery away from the mounting tabs to remove.
  10. HP 15-da0002dx SSD Replacement, SSD: Schritt 10, Bild 1 von 1
    • Remove the screw holding the SSD in place using the Phillips #1 screwdriver.
  11. HP 15-da0002dx SSD Replacement: Schritt 11, Bild 1 von 1
    • Carefully pull the SSD away from the socket.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Abigail Aron
941 Reputation
5 Anleitungen geschrieben
Ein Kommentar
sir
can we add a hdd of 1tb also without replacing ssd???
Kranti Ajit - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 23
Insgesamt: 2,066
