Einleitung
If your device is failing to have power and work without being plugged in, the battery may need to be replaced. Follow this guide to correctly remove it.
Was du brauchst
Using a Phillips #000 screwdriver, remove the eleven 10 mm screws located on the underside of the laptop, that are holding the back panel in place.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
