Zum Hauptinhalt wechseln
HP 15-db0015dx USB/SD Card Reader Replacement
Was du brauchst
  1. HP 15-db0015dx USB/SD Card Reader Replacement, Battery: Schritt 1, Bild 1 von 2 HP 15-db0015dx USB/SD Card Reader Replacement, Battery: Schritt 1, Bild 2 von 2
    • Power off the device before starting.
    • Remove the rubber strips that hide the screws using the spudger.
    • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
  2. HP 15-db0015dx USB/SD Card Reader Replacement: Schritt 2, Bild 1 von 3 HP 15-db0015dx USB/SD Card Reader Replacement: Schritt 2, Bild 2 von 3 HP 15-db0015dx USB/SD Card Reader Replacement: Schritt 2, Bild 3 von 3
    • Use the spudger tool to pry open the back cover.
    • Lift the back panel to access the inside.
    • Slide the CD drive to the left, and remove.
  3. HP 15-db0015dx USB/SD Card Reader Replacement: Schritt 3, Bild 1 von 3 HP 15-db0015dx USB/SD Card Reader Replacement: Schritt 3, Bild 2 von 3 HP 15-db0015dx USB/SD Card Reader Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the three battery screws with a Phillips #0 screwdriver.
    • Lift the battery up, disconnecting the connector first.
    • Push forward and remove the battery.
  4. HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: Schritt 4, Bild 1 von 3 HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: Schritt 4, Bild 2 von 3 HP 15-db0015dx USB/SD Card Reader Replacement, Hard Drive: Schritt 4, Bild 3 von 3
    • Remove the four screws on the hard drive bracket with a Phillips #0 screwdriver.
    • Pull the hard drive bracket out.
  5. HP 15-db0015dx USB/SD Card Reader Replacement: Schritt 5, Bild 1 von 1
    • Remove the hard drive from the connector by sliding it to the left until the connector is disengaged.
  6. HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: Schritt 6, Bild 1 von 3 HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: Schritt 6, Bild 2 von 3 HP 15-db0015dx USB/SD Card Reader Replacement, USB/SD Card Reader: Schritt 6, Bild 3 von 3
    • Lift up on the connector pin that attaches the SD card reader to the motherboard
    • Gently pull the wire out
  7. HP 15-db0015dx USB/SD Card Reader Replacement: Schritt 7, Bild 1 von 2 HP 15-db0015dx USB/SD Card Reader Replacement: Schritt 7, Bild 2 von 2
    • Snake the wire underneath the battery support
    • Pull the wire out to allow the SD Card reader to be removed
  8. HP 15-db0015dx USB/SD Card Reader Replacement: Schritt 8, Bild 1 von 3 HP 15-db0015dx USB/SD Card Reader Replacement: Schritt 8, Bild 2 von 3 HP 15-db0015dx USB/SD Card Reader Replacement: Schritt 8, Bild 3 von 3
    • Remove the two Phillips #0 screws holding the SD Card reader in place.
    • Gently pull the SD card reader up and out of the slot.
    • A spudger may have to be used to pop the SD card reader out of place.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 453
