Zum Hauptinhalt wechseln
HP 15-dw0037wm RAM Replacement
Was du brauchst
  1. HP 15-dw0037wm RAM Replacement, Lower Case: Schritt 1, Bild 1 von 2 HP 15-dw0037wm RAM Replacement, Lower Case: Schritt 1, Bild 2 von 2
    • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
    • Set the laptop down with the lower case facing up.
    • Lift a corner of the lower silicone foot and peel it completely off.
    • Repeat for the upper silicone foot.
  2. HP 15-dw0037wm RAM Replacement: Schritt 2, Bild 1 von 2 HP 15-dw0037wm RAM Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the five 8 mm screws.
    • Remove the two 5 mm Phillips screws.
  3. HP 15-dw0037wm RAM Replacement: Schritt 3, Bild 1 von 3 HP 15-dw0037wm RAM Replacement: Schritt 3, Bild 2 von 3 HP 15-dw0037wm RAM Replacement: Schritt 3, Bild 3 von 3
    • Insert an opening pick into the gap between the lower case and chassis.
    • Starting from a corner is recommended.
    • Slide the pick around the entire perimeter of the device until the lower case fully releases.
    • Remove the lower case.
  4. HP 15-dw0037wm RAM Replacement, RAM: Schritt 4, Bild 1 von 3 HP 15-dw0037wm RAM Replacement, RAM: Schritt 4, Bild 2 von 3 HP 15-dw0037wm RAM Replacement, RAM: Schritt 4, Bild 3 von 3
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
  5. HP 15-dw0037wm RAM Replacement: Schritt 5, Bild 1 von 3 HP 15-dw0037wm RAM Replacement: Schritt 5, Bild 2 von 3 HP 15-dw0037wm RAM Replacement: Schritt 5, Bild 3 von 3
    • Grab the RAM by the exposed side and gently remove it.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Emily Davila
651 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 16
Insgesamt: 112
