Zum Hauptinhalt wechseln
HP 15-dy2024nr Back Cover Replacement
Was du brauchst
  1. HP 15-dy2024nr Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 2 HP 15-dy2024nr Back Cover Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
    • Gently peel the feet from the laptop using the spudger revealing the screws underneath.
    • If the rubber foot peels away but leaves adhesive behind you must peel the adhesive away before removing the screws.
  2. HP 15-dy2024nr Back Cover Replacement: Schritt 2, Bild 1 von 3 HP 15-dy2024nr Back Cover Replacement: Schritt 2, Bild 2 von 3 HP 15-dy2024nr Back Cover Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove:
    • Two 2.5mm x 6mm screws
    • Six 2mm x 6mm screws
    • Be sure to keep different screw sizes separated.
  3. HP 15-dy2024nr Back Cover Replacement: Schritt 3, Bild 1 von 3 HP 15-dy2024nr Back Cover Replacement: Schritt 3, Bild 2 von 3 HP 15-dy2024nr Back Cover Replacement: Schritt 3, Bild 3 von 3
    • Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
    • Using another iFixit opening tool, slide along the seam to unhook the clips.
    • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
    • When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
    • After the clips have been released, flip the laptop over and lift the cover.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Konnor Young
523 Reputation
4 Anleitungen geschrieben
Utah Tech University, Team 1-4, McMurrin Fall 2022 Mitglied von Utah Tech University, Team 1-4, McMurrin Fall 2022
UTAHTECH-MCMURRIN-F22S1G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 45
Insgesamt: 982
